This guide will show you how to replace the headband on the Anker Soundcore Life Q30 Headphones. The headband is the plastic piece that runs along the top frame of the headphones. The headband can be damaged over time, so replacing it lets the user continue wearing them with the same level of comfort. During this process, it will be important to not disconnect or damage the wire that runs under the headband.
Unscrew the two 9.5mm screws from the interior side of the headband using a Phillips #00 screwdriver.
Use the opening tool to pry off the exterior covering of the headband.
Slide the headband off the lateral extension of the headphones.
Orient the headphones such that you are looking at where you originally removed the covering.
Unscrew the 2 visible 5.7mm screws on each side using a Phillips #00 screwdriver.
Slide off the metal part of the headband from the plastic casing.
Gently bend the headband back and forth to loosen the cushion.
You can now remove the headband by gently peeling it off of the frame.
You can attach your replacement headband. This will need to be glued into place. From here, follow these steps in reverse order to reassemble the device.
crwdns2947412:07crwdne2947412:0
Hello, i need to do this procedure, but i need to know where to buy the headband to do so, can you help me?
me too! i need to buy in Brazil.
Did someone found how to buy the headband? I apreciate the help!
yeah me too where i can find it?
I've seen some 3D prints available for the parts. I forget where it is but I found it on a Reddit post regarding the side headband pieces
