Anker Soundcore Flare Mini Audio Drivers Replacement
    1. Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The rubber cover of the speaker is glued down.
      • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
    2. Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
      • Use your hand to pull the plastic cover off the bottom of the speaker.
    1. Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement, Motherboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
      • Lift the motherboard up.
      • The motherboard is still attached to several wires underneath.
    2. Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
      • When removing the power connectors, do not pull the wires themselves.
      • Remove the motherboard from the speaker.
    1. Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement, Waterproof Outer Shell: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
      • Remove the white plastic cover from the speaker.
    2. Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
    3. Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the charging port away from the side of the speaker.
    4. Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a spudger to loosen the cover from the inner components of the speaker.
      • Slide the cover completely off.
      • One wire will still be connected to the shell.
    1. Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement, Audio Drivers: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • There are two drivers—one on each side of the speaker.
      • Use a Phillips #1 screwdriver to remove the four 11 mm screws from one driver.
      • Use your hand to pull the driver out of the device.
      • Repeat this step with the other driver.
    2. Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Flare Mini Audio Drivers Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use precision tweezers to detach the two wire connectors from the driver.
      • Both drivers are connected to the same wire so removing one side will separate the other driver from the device as well.
      • Remove both drivers from the device.
Ethan Holland
crwdns2935283:001/08/22crwdne2935283:0
560 crwdns2915208:0crwdne2915208:0
Illinois Wesleyan University, Team 1-1, Bullock Spring 2022 crwdns2935289:0Illinois Wesleyan University, Team 1-1, Bullock Spring 2022crwdne2935289:0
IWU-BULLOCK-S22S1G1
what size are the speakers?
Chris - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 1,576
