Anker Soundcore Boom 2 Waterproof Gasket Replacement
  1. Anker Soundcore Boom 2 Waterproof Gasket Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Boom 2 Waterproof Gasket Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to gently pry the front panel off of the speaker.
    • Start with the top of the panel, pressing in and down on the middle of the top of the panel to release the tab holding it in place.
  2. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue around edge of the front panel, releasing each tab until the panel is loose and comes free.
    • Some speaker models have a strong adhesive around the edge of the panel that may require heat or glue-remover to loosen.
  3. Anker Soundcore Boom 2 Waterproof Gasket Replacement, Speaker Head: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Boom 2 Waterproof Gasket Replacement, Speaker Head: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips head screwdriver to remove the 8 screws surrounding the speaker head on the front facing panel.
  4. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to remove the top plate off of the handle.
  5. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 screws in the handle with a Phillips head screwdriver.
  6. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to separate the front facing panel from the rear facing panel.
    • Follow the seam all the way around the device, prying gently until a gap appears before moving further along.
    • This will split the device from front and back.
  7. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use pliers to disconnect the speaker head from the motherboard.
  8. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips head screwdriver to remove the 6 screws around the backside of the speaker head.
  9. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker head from the front facing panel.
  10. Anker Soundcore Boom 2 Waterproof Gasket Replacement, Button Panel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to gently disconnect the motherboard ribbon cable from the button panel.
  11. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use pliers or tweezers to disconnect the microphone cable and the button wire from the motherboard.
  12. Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Boom 2 Waterproof Gasket Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips head screwdriver to remove the 8 screws from the button panel.
    • Carefully slide the button panel out of place.
  13. Anker Soundcore Boom 2 Waterproof Gasket Replacement, Waterproof Gasket: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Boom 2 Waterproof Gasket Replacement, Waterproof Gasket: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the device pulled apart and the wires to the speaker head and button panel disconnected, remove the gasket from around the edge of the internal compartment.
Cole Enos-Waffles
crwdns2935283:003/24/25crwdne2935283:0
641 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-3, Biswokarma Spring 2025 crwdns2935289:0UMass Dartmouth, Team 5-3, Biswokarma Spring 2025crwdne2935289:0
UMASSD-BISWOKARMA-S25S5G3
crwdns2942667:0crwdne2942667:0 118
