This guide applies to the Anker Soundcore Boom 2 Speaker, model number A3138.
The following replacement guide covers how to remove and replace the speaker head of the device. This part creates and amplifies the soundwaves that the device puts out. Speaker heads are often what we think of when we envision a speaker device.
Signs that it's time to replace the speaker head are poor or no audio, clicks and popping sounds, or visible damage to the part.
Use a metal spudger to gently pry the front panel off of the speaker.
Start with the top of the panel, pressing in and down on the middle of the top of the panel to release the tab holding it in place.
Continue around edge of the front panel, releasing each tab until the panel is loose and comes free.
Use a Phillips head screwdriver to remove the 8 screws surrounding the speaker head on the front facing panel.
Use a spudger to remove the top plate off of the handle.
Remove the 3 screws in the handle with a Phillips head screwdriver.
Use a spudger to separate the front facing panel from the rear facing panel.
Follow the seam all the way around the device, prying gently until a gap appears before moving further along.
Use pliers to disconnect the speaker head from the motherboard.
Use a Phillips head screwdriver to remove the 6 screws around the backside of the speaker head.
Remove the speaker head from the front facing panel.
