Anker 2.4G Wireless Mouse Sensor Replacement
  1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your Phillips screwdriver, remove the four screws.
  3. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
    • Make sure you are not using too much pressure, as you could warp the plastic.
  4. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wires from the white crimping headers.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the scroll wheel from the motherboard by pulling it to the left.
    • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
  6. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Anti-Static Wrist Strap
    $7.95
    • Gently lift the motherboard away from the plastic housing.
    • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
  7. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the six wires holding the I.C. in place to complete the sensor change.
    • Replace the broken sensor with the new sensor and solder back in place.
    • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
Ryan
crwdns2935283:001/23/14crwdne2935283:0
140 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-39, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-39, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G39
crwdns2942667:0crwdne2942667:0 8,048
