Anker 2.4G Wireless Mouse Sensor Replacement
crwdns2869540:0crwdne2869540:0: 8,8 mil
4
20
93
8.751
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:015crwdne2931287:0
This manual shows how to simply replace the sensor on the Anker 2.4G wireless mouse. Before moving on with the first step, check the battery casing for any corrosion or visible damage. Beware, this guide requires use of a soldering iron which needs to be handled with caution. The instructions on how to solder can be found here How To Solder and Desolder Connections.
    1. Anker 2.4G Wireless Mouse Sensor Replacement, Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a spudger, carefully pry off the stickers to reveal the location of four screws.
    2. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your Phillips screwdriver, remove the four screws.
    3. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a spudger, carefully pry apart the upper and lower housing of the mouse.
      • Make sure you are not using too much pressure, as you could warp the plastic.
    4. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the wires from the white crimping headers.
      • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
    5. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the scroll wheel from the motherboard by pulling it to the left.
      • This may take some force to remove. Make sure to pull it parallel to the board, instead of perpendicularly.
    6. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Anti-Static Wrist Strap
      $7.95
      • Gently lift the motherboard away from the plastic housing.
      • Use an iFixit grounding strap or another antistatic measure to prevent sensitive components from electrostatic discharge during this step.
    7. Anker 2.4G Wireless Mouse Sensor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the six wires holding the I.C. in place to complete the sensor change.
      • Replace the broken sensor with the new sensor and solder back in place.
      • Make sure none of your solder connections are bridged as this can cause serious damage to your mouse.
Ryan
crwdns2935283:001/23/14crwdne2935283:0
152 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-39, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-39, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G39
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 93
crwdns2959996:0crwdne2959996:0 8,751
