Android tablet Nobis NB09 Screen Replacement
  1. Android tablet Nobis NB09 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Android tablet Nobis NB09 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Android tablet Nobis NB09 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 00 Phillips screws located on the right side of the tablet.
    • Use the plastic opening tools to loosen and then pry the back if the tablet off.
    • When prying off the back of the tablet, be careful around the tablets ports. Too much pressure can cause cracks.
  2. Android tablet Nobis NB09 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Android tablet Nobis NB09 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Android tablet Nobis NB09 Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It is recommended that a grounding bracelet be used in order to avoid damage to the device's circuits through ESD (Electro-Static Discharge)
    • Remove the electrical tape covering the motherboard.
    • Remove the four 4.0 mm T4 Torx screws holding the motherboard to the front half of the tablet.
    • Remove any remaining adhesive tape on the exposed area.
    • Disconnect the ribbon cable attachments by lightly pushing up the locking arm (black tab) on each then gently detaching the pin connectors.
  3. Android tablet Nobis NB09 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Android tablet Nobis NB09 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Android tablet Nobis NB09 Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the notch on the digitzer, located on the left side of the device.
    • Use the Phillips Screwdriver to gently push the notch and lift the digitizer from the screen.
  4. Android tablet Nobis NB09 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Android tablet Nobis NB09 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Android tablet Nobis NB09 Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide the digitizer from its clasps to remove it from the screen.
    • The digitizer should now be removed separately from the screen.
Enea Osmann
crwdns2935283:010/31/14crwdne2935283:0
158 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-1, Cichon Spring 2015 crwdns2935289:0UMass Dartmouth, Team 7-1, Cichon Spring 2015crwdne2935289:0
UMASSD-CICHON-S15S7G1
The digitizer replacement instructions was great. Thanks
steven warren - crwdns2934203:0crwdne2934203:0
My screen is busted that has the sensor in it do I have to buy a screen or can I use a keyboard?
April sharp - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,508
