Android tablet Digitiser Replacement
    • I have no sophisticated device to unglue the bezel. What I did is use a small kitchen oven. The top of the oven becomes hot when I’m using it. I set it to 6 (180C), then I placed the digitiser assembly face down on the top of the oven (not inside!). After 5 minutes, I inserted a kitchen knife between digitiser and bezel and separated them.
    • In order to clean the bezel, I recommend to use alcohol. I tried with nail polish remover and it is too strong, it damages the bezel. Alcohol is less aggressive and it will take a little more mechanical effort, yet I could do it.
    • After I cleaned the bezel, I removed the protective film off the inner side of the digitiser. I removed the protecting straps of the double sided tape, then carefully pulled the flat cable through the hole and glued the digitiser with the bezel to form the digitiser assembly.
    • The digitiser shouldn’ Be stained as you just removed the protecting film. The screen might well be dirty. Remember it is highly sensitive to touch. Therefore, I used a dry cloth to softly brush off the small glass pieces. Don’t overdo, just brush them off without exercising any pressure.
    • Just redo the steps you needed to disassemble the tablet in reverse order...
bclabots
crwdns2935283:012/15/13crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 178
