This guide will show you how to replace the battery in an Android Nobis NB09 tablet.
Some possible symptoms which could show that your tablet's battery is dying include:
- Battery is at a low percentage even after a fresh charge.
- The tablet dies when it still has a lot of battery life.
- The tablet becomes hot after using for a short period of time.
If you experience any of these symptoms, then it is likely the culprit is a failing battery.
Remove the screws holding the case together.
Use an opening tool to loosen and pry off the pink back plate.
Remove the black electronic tape covering the circuit board.
Use the soldering iron to remove the black and red wires from the circuit board.
Gently loosen the adhesive under the battery to avoid damaging it.
crwdns2917034:0crwdne2917034:0
where can i buy a battery from
