crwdns2936621:0crwdne2936621:0
To switch off the phone press and hold the volume down and the power buttons to open the Power off menu.
Switch off the device.
Connect the device to the PC.
NOTE: Connecting the device to a PC/Mac is only required if you are planning on applying an update over ADB or if you are putting files on the device.
Press and hold the Volume up and the power on buttons.
When you see the Samsung logo release only the Power button.
To use the Android Recovery menu use the Volume Up/Down buttons to navigate and the Power On button to select.
I have tried this many times and my phone just keeps turning back on. Is there any other way to access the recovery menu
i would really love to know this too. i have been trying to do the same and the phone just turns on. or is stuck in a boot loop until i release the volume up button
I had the same problem. Try to completely discharge the battery, until the phone won't turn on. Then hold volume up and power button, an then connect the phone to the charging cable. Then same procedure as described. Worked for me when the USB cable was connected to my notebook.
thank u my mate fingers crossed
not doing anything yet
s20u 5533
352712248043145756
35400566043145456
fix
SIR HIK ME IME S20U 352712248043145756
35400566043145456
