Anbernic RG 40XXV Battery Replacement
  1. Anbernic RG 40XXV Battery Replacement, Back Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG 40XXV Battery Replacement, Back Panel Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG 40XXV Battery Replacement, Back Panel Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the micro SD card located on the left and right sides of the device by pushing into the SD card slot and pulling the card out.
    • Unscrew all six 7.5 mm screws on the backside of the case using a 1.5 mm hex screwdriver.
  2. Anbernic RG 40XXV Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG 40XXV Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take apart the case by separating the front and back sides using an iFixit opening tool.
    • When using the opening tool, carefully pry open the case to avoid damaging the device.
  3. Anbernic RG 40XXV Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG 40XXV Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery connection cable by gently pulling it away with angled tweezers from the slot that connects the cable to the motherboard.
    • The cable connection to the motherboard is labeled "+BAT-" for easy identification.
  4. Anbernic RG 40XXV Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG 40XXV Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG 40XXV Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide a nylon spudger under the battery.
    • Gently pry the battery from the case, releasing the glue holding it in place.
    • If the battery will not come loose, applying force with the nylon spudger at different points of entry may help to free it. Using a hair dryer or heat gun may be helpful to further loosen the glue.
    • When dislodging the battery, be careful not to puncture the battery or battery wrapping to avoid further damaging the device or harming yourself.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device.
  5. Anbernic RG 40XXV Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery to remove.
Stevie Anne Hebert
crwdns2935283:002/25/25crwdne2935283:0
389 crwdns2915208:0crwdne2915208:0
Idaho State University, Team 1-2, Watkins Spring 2025 crwdns2935289:0Idaho State University, Team 1-2, Watkins Spring 2025crwdne2935289:0
ISU-WATKINS-S25S1G2
crwdns2936753:030crwdne2936753:0 86
crwdns2942667:0crwdne2942667:0 465
