Ambient Weather WS-1001-Wifi LCD Screen Replacement
  1. Ambient Weather WS-1001-Wifi LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, you will need to remove all four M2x1-7 screws (7mm length) located on the back of the device. This should be done using a Phillips #1 screw driver.
  2. Ambient Weather WS-1001-Wifi LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the side of the device use the plastic opening tool to pry the gray front casing from the rear black casing.
    • The ribbon cable is attached inside so the two pieces will not come completely apart. See step 3.
  3. Ambient Weather WS-1001-Wifi LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, carefully press the black bar towards the ribbon and away from the white bar in order to release it.
    • The ribbon cable should come out and be attached to the back of the LCD screen resulting in two separate pieces.
  4. Ambient Weather WS-1001-Wifi LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ambient Weather WS-1001-Wifi LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, you need to remove the LCD screen from the front casing.
    • Push on the front of the LCD screen to pop it out as seen in picture 2.
Jeremiah Miskimen
crwdns2935283:011/06/17crwdne2935283:0
107 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G2, Harley Fall 2017 crwdns2935289:0IUPUI, Team S1-G2, Harley Fall 2017crwdne2935289:0
IUPUI-HARLEY-F17S1G2
Pretty useless guide since this is all pretty self explanatory with no reference on where to get a replacement or even a part number
Jared Dykstra - crwdns2934203:0crwdne2934203:0
Exactly right.
j drag -
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 396
