AmazonBasics BTV1 Battery Replacement
  1. AmazonBasics BTV1 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AmazonBasics BTV1 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AmazonBasics BTV1 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AmazonBasics BTV1 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AmazonBasics BTV1 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AmazonBasics BTV1 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard off the face plate, exposing the battery.
    • Lift the battery out of its housing.
    • Use caution when using tools around the battery; batteries can be dangerous if punctured.
    Where can I get a replacement battery for the speaker?
    Joe (Joeman21) - crwdns2934203:0crwdne2934203:0
crwdns2935229:010crwdne2935229:0
Chris Shannon
crwdns2935283:002/01/16crwdne2935283:0
1.039 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-2, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 14-2, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S14G2
crwdns2947412:08crwdne2947412:0
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - crwdns2934203:0crwdne2934203:0
Need information on where to get a replacement battery!
dan - crwdns2934203:0crwdne2934203:0
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - crwdns2934203:0crwdne2934203:0
It’s an AEC653055 battery 3.7v 1000mAh
Ross - crwdns2934203:0crwdne2934203:0
Yes, but where can I get one? A lot of what’s available on Amazon (for example) has reversed polarity (black/red switched). Be great if someone could post link to specific product. I just replaced batteries in two Lenovo Yogas (4 years old), from IFixIt. And independently sourced battery for my Jabra 75 headset (5 years old). I’m a total convert!
frank g -
This is the only place I could find an exact match (https://www.aliexpress.us/item/325680233...). Unfortunately, it won't let me log in, and delivery times appear quite long (to US): about two months.
frank g - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,272
