This repair would be necessary if the plastic drive gears within the AmazonBasics stripped, meaning the teeth were either ground down or broke off. A telltale sign of this is if you can hear the motor spinning, but the shredding blades do not move.
Remove the shredder assembly from the paper scrap bin.
Remove the two 10mm PH1 screws holding the small black panel in place.
Remove the six 14mm PH1 screws holding the bottom cover in place.
Remove the cover by lifting straight upwards.
Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
Remove the five 8mm PH2 screws from the bracket holding the gears in place.
Use a metal spudger to pry the bracket from the main shredder assembly.
Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
Where does one buy these gear parts?
Hi, you can buy the gear here: https://www.ebay.com/itm/116169745117
I need big wheel for Bonsaii C220-A and need a duel gear wheel (1.6 inches and 0.5 inches) Apelila Apelila paper shredder
