AmazonBasics B0050BPWBQ On/Off Switch Replacement
  1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The unit head needs to be switched to the off position and unplugged before any disassembly.
    • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
    • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
  2. AmazonBasics B0050BPWBQ On/Off Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AmazonBasics B0050BPWBQ On/Off Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
    • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
  3. AmazonBasics B0050BPWBQ On/Off Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the back panel away from the front panel on a flat surface.
    • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
  4. AmazonBasics B0050BPWBQ On/Off Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AmazonBasics B0050BPWBQ On/Off Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the green control board that is located next to the shredding motor.
    • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
    • You may need to move wires over to find the screws.
  5. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the front panel away from the shredding unit.
    • Locate the black On/Off switch attached to the front panel where the control board was once attached.
    • Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
Natalie Meert
crwdns2935283:002/11/16crwdne2935283:0
690 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-4, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 2-4, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S2G4
Does anyone know where to buy a replacement switch?
Shawn - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,673
