Removing the front plate of your Amazon Luna Controller is a crucial first step if you need to replace a damaged front plate or access internal components for repairs. Before you begin, ensure your controller is powered off to prevent accidental damage.
Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
Hold the controller firmly.
Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
Work slowly and carefully around all sides to avoid snapping the clips.
Once all clips are released, lift the front plate away from the controller.
