If the front cover of your Amazon Kindle 8 is damaged or preventing proper screen visibility, use this guide to replace it.
The front cover protects the screen from damage and enhances user comfort during reading. A damaged front cover can reduce screen visibility or cause damage to the display.
Before beginning, make sure that the screen itself is not damaged and clean. Replacing the front cover will not resolve screen-related issues.
Handle the front cover with care during removal to avoid damaging the display or underlying components.
Insert the iFixit opening tool into any corner of the Kindle’s front cover.
Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
Lift front cover once all clips are disengaged.
Insert the spudger between the inner cover and the screen.
Gently work your way around to loosen the front cover.
Carefully lift the front cover from the device.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
