If the back cover of your Amazon Kindle 8 is damaged, use this guide to replace it.
The back cover protects the Kindle's internal components from damages. A damaged back cover can interfere with the kindle's durability and functionality.
Before beginning, make sure that the back cover isn't simply loose and can't be resecured without replacement.
Be cautions when prying off the back cover to avoid damaging clips or internal components.
Insert the iFixit opening tool into any corner of the Kindle’s front cover.
Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
Lift front cover once all clips are disengaged.
Insert the spudger between the inner cover and the screen.
Gently work your way around to loosen the front cover.
Carefully lift the front cover from the device.
Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
Lift the screen and motherboard from the back cover.
Separate the motherboard and the back cover.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
