crwdns2959928:0crwdne2959928:0 ↓This guide takes you step by step through the process required to remove the buttons on the Amazon Fire remote. This task is simple and should not take more than a few minutes. To complete this you will need a plastic opening tool, triangle screwdriver, and a pair of precision tweezers. If you follow the easy steps you will successfully remove the buttons on the remote.
To remove the buttons use the blue plastic opening tool to pry out the outer ring.
Remove top plate using plastic opening tools.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to push out the buttons.
Where do you get the replacement parts
Chris S - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You could probably find them on eBay.
[deleted] - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
All the Amazon remote repair guides here need updating as many generations have come out since this original basic edition shown here. There are at least six other versions outside of this one. https://www.amazon.com/gp/help/customer/...
deilert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
