crwdns2959928:0crwdne2959928:0 ↓This guide takes you step by step through the process required to replace the batteries of the Amazon Fire TV Stick remote. This task is simple and should not take more than a few minutes. To complete this you will need a plastic opening tool and two new batteries. If you follow the easy steps you will successfully change the remote batteries in your Amazon fireTV stick.
×2
Use the plastic opening tool to press into the seam between the remote and battery cover.
With the same tool to help pop the batteries out.
Place two fresh batteries back inside the remote and slide the cover back on.
crwdns2947412:035crwdne2947412:0
do you have to use amazon batteries...my remote doesn't work with duracell
mtimken - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hey @mtimken ! As far we know, there isnt anything special about Amazon's AAA batteries. Any two *new* AAA batteries should work just fine. Are you certain both of your Duracell batteries are new? Are they rechargeable batteries that need to be charged up fully? Let us know what you find out! Good luck.
Kelsea Weber - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
That's my question what type of batteries do I need for my Amazon Fire stick
biba.anderson41 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The remote takes two AAA batteries. See the answer to the comment above. In the future, go ahead and post your question in the Answers forum : ifixit.com/answers. You may get an answer faster by posting where all of our community members can see your question. I hope this helps. Happy fixing!
Hello having problem with firestick Remote cant get it to work ? i change batteries still not working?
denise carter - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
