Amazon Fire Phone Micro-USB Port Replacement
  1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
    I kind of like the way the battery just “disappears” between step 5 and 6; mine was glued in with a REALLY good quality adhesive tape that took some chiseling to get free; happily, the battery didn’t explode, hopefully it will still work.
    vincentfasano - crwdns2934203:0crwdne2934203:0
  5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
    Single hardest step, removing this battery takes both time and the jaws of life, it has an adhesive strip that will nearly RIP the battery or motherboard of the phone part, just keep careful while your at it, both mine and my wifes survived the tearing of this battery out, iv never been so sure I was breaking something while removing the battery but they went back together very easily once the devil adhesive let the battery go. This battery the the differential between a 1star difficulty and the 5star difficulty.
    Isaaru Narom - crwdns2934203:0crwdne2934203:0
    I didn’t know Amazon made a phone it looks like iPhone when you opened it nice guide man
    Maxem - crwdns2934203:0crwdne2934203:0
  6. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
  7. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
  8. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
  9. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
  10. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
    Boy, that could use a little more detail - pry camera from camera holder accompanied by a pic in which the fingernails and only the fingernails are in focus kind of leaves us wanting more…
  11. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off bottom plastic piece with flat antenna cables
    we really don’t have a feel for focus in this camera, do we?
    how to change the charging port
    hamzahassan22222 -
Kent Kawahara
crwdns2935283:010/01/15crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-7, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 5-7, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S5G7
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,530
