Amazon Fire Phone Micro-USB Port Replacement
  1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
  5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
  6. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
  7. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
  8. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
  9. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
  10. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
  11. Amazon Fire Phone Micro-USB Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off bottom plastic piece with flat antenna cables
Kent Kawahara
crwdns2935283:010/01/15crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-7, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 5-7, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S5G7
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,662
