Amazon Fire Phone Headphone Jack Replacement
  1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the display is damaged use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your phone.
    • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the single suction cup just above the home button.
    • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
  4. Amazon Fire Phone Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Headphone Jack Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 1mm screw concealed in the headphone jack.
    • Afterwards the headphone jack will easily pop off.
    i need this casing back cover
    Kashif Arif - crwdns2934203:0crwdne2934203:0
Savannah Moen
crwdns2935283:010/29/15crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-7, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 5-7, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S5G7
hello sir i need amazon fire back casing in Pakistan
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,932
