Use this guide to replace the rear case on a Amazon Fire HD 8 Plus 12th Gen.
Insert an opening pick into the seam between the rear case and the screen assembly.
Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
