Amazon Fire HD 8 Plus 12th Gen Battery Replacement
  1. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the charger, power down the device, and remove the SD card before beginning.
    • Insert an opening pick into the seam between the rear case and the screen assembly.
    • Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
    • Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
    • Be patient and don't pry too hard in any specific place. Excessive force may cause damage to the device.
  2. Amazon Fire HD 8 Plus 12th Gen Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear case.
  3. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Amazon Fire HD 8 Plus 12th Gen Battery Disconnection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to lift the battery connector until it disconnects.
  4. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently and slowly grip and pull the three white adhesive tabs that secure the battery until they fully release.
    • The adhesives are marked with a black flap with a white adhesive. You will know it has been successfully removed when you can move the battery around.
  5. Amazon Fire HD 8 Plus 12th Gen Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire HD 8 Plus 12th Gen Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire HD 8 Plus 12th Gen Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry around the entire perimeter of the battery with an opening tool until the adhesive releases.
    • Remove the battery.
    • Take care not to bend or puncture the battery while prying the battery.
    • Clean under the old battery and insert a new battery with adhesive to ensure the battery stays in place.
To reassemble your device, follow these instructions in reverse order. Make sure you have a applied a adhesive for the new battery to make sure it stays in place.
Alan Alejandro Ramos Avalos
crwdns2935283:002/05/24crwdne2935283:0
547 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-7, Kilpatrick Spring 2024 crwdns2935289:0University of North Texas, Team 2-7, Kilpatrick Spring 2024crwdne2935289:0
UNT-KILPATRICK-S24S2G7
crwdns2942667:0crwdne2942667:0 334
