Using a Jimmy, start at the volume control and work your way around by prying off the back and then lifting it back like a book.
Peel off the 2 yellow pieces of yellow tape on the battery.
Take off all the ribbon cables connected to the main board. (Marked in Red)
On the 2 speakers marked in yellow, be sure to pull straight up. Then unclip the speaker cables.
Using a T4 Torx driver, unscrew each of the 2 screws holding in the 2 speakers. (red)
Then, take out the 7 screws hold in the gray bracket (yellow)
Now, unscrew the 8 screws holding the motherboard. (green)
Next, use a T4 Torx Screwdriver again to unscrew the headphone jack and the Micro USB port.
1. Remove the Headphone and USB ports.
2. Remove motherboard.
3. Remove the speakers.
4. Remove gray bracket with battery.
Now, using a T4, unscrew the 4 screws holding in the screen.
Congrats! Now follow the directions in reverse to reassemble your Fire!
So cool I can't wait to retire my 5th generation fire tablet and tear it down
Please where can I get the digitizer?
Mine is shattered and I haven't used it for over 3years but I can still power it up.
Will very much appreciate a lead.
Patrick,
Nigeria
