Amazon Fire HD 10 Screen Replacement
  1. Amazon Fire HD 10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire HD 10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire HD 10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
    The right side with the power switch on top?
    Sonny Shear - crwdns2934203:0crwdne2934203:0
    Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
    Thanks!
    Steve Ciciora - crwdns2934203:0crwdne2934203:0
    What if there are no pull tabs? It is stuck down on both sides in a metal tray. This is an hd 10 plus 11th generation.
    Traci R - crwdns2934203:0crwdne2934203:0
  2. Amazon Fire HD 10 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
    What is a ZIP connector? What does it look like?
    Beldenr - crwdns2934203:0crwdne2934203:0
    Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
    Adam O'Camb -
  3. Amazon Fire HD 10 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire HD 10 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen and digitizer from the case completely.
crwdns2935229:027crwdne2935229:0
Jaie Hillery
crwdns2935283:010/07/14crwdne2935283:0
1.757 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 16-6, Blackwell Winter 2016 crwdns2935289:0USF Tampa, Team 16-6, Blackwell Winter 2016crwdne2935289:0
USFT-BLACKWELL-W16S16G6
crwdns2935297:022crwdne2935297:0
crwdns2947412:017crwdne2947412:0
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - crwdns2934203:0crwdne2934203:0
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - crwdns2934203:0crwdne2934203:0
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - crwdns2934203:0crwdne2934203:0
What is needed to attach the screen back to the case?
Jimmy Lee - crwdns2934203:0crwdne2934203:0
I think you just snap it on. Not sure, I haven’t fixed mine yet.
[deleted] -
what best double sided tape for kindle hd 10 digitizer repair?
carl schnitzer - crwdns2934203:0crwdne2934203:0
Cheaper to buy a new one and keep the broken one in the car or garage.
Francisco Garay - crwdns2934203:0crwdne2934203:0
This is true. Going forward, I’d recommend getting the kid’s edition no matter what. It is a great insurance policy. Amazon honors their warranty nicely…
Daniel Jacobovitz -
Does anybody know if the 2017 model uses the same screen and/or digitizer as the 2015 model?
bhicks0316 - crwdns2934203:0crwdne2934203:0
That is only the glass, and not the LCD… This guide doesn’t include the steps to separate the glass from the LCD assembly…
Daniel Jacobovitz -
This did not work for me. I wonder if it changed in newer models ? I pried it open on the side, then the whole back cover came off. It was impossible to separate the glass from the rest without breaking it all. Wonder what I did wrong.
Lennart Pascal Tarris - crwdns2934203:0crwdne2934203:0
Extremely simple and very well documented. Thank you for making the replacement less difficult. Just one question, how do you get the plastic tool to fit in between the screen and the frame? Mine wore out trying to scrape and push its way in there
Joseph Richard - crwdns2934203:0crwdne2934203:0
Too bad the cost of the part is so high.
Charles Woznak - crwdns2934203:0crwdne2934203:0
Anyone try using this screen in other projects? I am looking for an adapter for the ribbon cable to HDMI or DPSI
Joe Steele - crwdns2934203:0crwdne2934203:0
My screen comes on but I cannot read anything I have lines all colors on screen,
Responds to touch,
I rebooted etc
What's the deal please?
Murphy - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 151
crwdns2942667:0crwdne2942667:0 38,094
