Use this guide to replace the motherboard in your Amazon Fire HD 10.
Use a plastic opening tool to pry the screen up in the right hand corner.
Lift the screen and digitizer from the case.
Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
Remove the screen and digitizer from the case completely.
Locate the power cable that links the battery to the motherboard.
Carefully unplug the battery power cable to disconnect the battery from the motherboard.
Begin by locating the double sided pull tape locations.
Pull the black soft tabs to release the tape's adhesion.
Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
After the battery is totally free of any adhesion, simply lift the battery from the case.
Remove the single T5 Torx screw at the base of the camera.
Lift the camera from the case using the plastic opening tool.
Gently grab the camera and pull to remove.
The camera is now free from the motherboard.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
Lift the black plastic cover once the screws are removed.
Place aside for later reassembly.
Detach the connector using a plastic opening tool or spudger.
Grip the camera and lift up to detach the ZIF connector from the motherboard.
Lift the ZIF connector up to disconnect from the motherboard.
Disconnect the connectors using the plastic opening tool.
Remove the ten T5 Torx screws securing the motherboard to the case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift and pull the motherboard down, gently, towards the case using the tweezers.
crwdns2935229:014crwdne2935229:0
Just for the record, my screws were T4, not T5.
Where is a reliable store to buy this motherboard?
what you left out is the speakers are they still attached to the motherboard you get 15 points
Is this the Kindle? Not the Tablet?
I have exhausted all online searches for a new HD Fire 10.1 7 generation motherboard replacement and have not been able to locate one anywhere do you have any places you know of that sell these types of motherboards?
Thanks,
Al Silva
