Before you begin, make sure the device is off. You will need to use the screen replacement guide as a prerequisite.
Use a plastic opening tool to pry the screen up in the right hand corner.
Lift the screen and digitizer from the case.
What is a ZIP connector? What does it look like?
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
Remove the screen and digitizer from the case completely.
Locate the power cable that links the battery to the motherboard.
Carefully unplug the battery power cable to disconnect the battery from the motherboard.
Battery removal is optional for the motherboard, but is a great addition to this guide for completeness.
Begin by locating the double sided pull tape locations.
Pull the black soft tabs to release the tape's adhesion.
Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
Why not heating the tabs a little to take battery easier
There are no tabs on mine. Hd10 plus 11th gen. Can I just buy a new battery tray? Where?
After the battery is totally free of any adhesion, simply lift the battery from the case.
crwdns2935229:011crwdne2935229:0
crwdns2947412:09crwdne2947412:0
why is there so much empty space next to the battery?
Big screen, little processor. The screen dictates the space, that’s why the battery has to be secured with adhesive.
ctgblue -
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
ctgblue -
How do you know if ita battery or charging port? Mine dont do anything whe. Its
That’s my question also. How do you know if it is the battery or the port?
Fitted battery replacement now won't start up any clues where iv gone wrong?
This is amazing, my mom and dad won't have to spend money on buying a new tablet and I get to save my tablet witch has Malayalam memory's for me even though it sucks (just I gotta save up for the tools)
Should new adhesive be used for securing the two halves of the shell back together? And if so, what kind?
The right side with the power switch on top?
Sonny Shear - crwdns2934203:0crwdne2934203:0
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - crwdns2934203:0crwdne2934203:0
What if there are no pull tabs? It is stuck down on both sides in a metal tray. This is an hd 10 plus 11th generation.
Traci R - crwdns2934203:0crwdne2934203:0
