This guide will show you how to replace the woofer, the speaker in the Amazon Echo responsible for the low-frequency bass. This guide should be helpful if your Echo is lacking bass or sounds otherwise distorted.
Peel off the rubber footing from the bottom of the Echo.
Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
Peel off the black fabric wrapped around the Echo.
Remove the four 42.8 mm T10 Torx screws around the tweeter.
Lift the tweeter and its attached housing from the device.
Lift the woofer out of the Echo.
Where can you buy a replacement woofer?
My exact question.
Could you post the dimension of the woofer unit? Its depth and diameter (and possibly screw holes location/diameter)? That would be very useful. Thank you.
