crwdns2959928:0crwdne2959928:0 ↓This guide demonstrates how to replace the tweeter assembly in the Amazon Echo. Removing the assembly is a prerequisite for replacing the tweeter or woofer.
Peel off the rubber footing from the bottom of the Echo.
Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
Peel off the black fabric wrapped around the Echo.
Remove the four 42.8 mm T10 Torx screws around the tweeter.
Lift the tweeter and its attached housing from the device.
I've gotten this far, but where do you get a replacement? No brand or model # on tweeter.
Kyle - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
kathy1557 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
Ron Davis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
