Amazon Echo Studio Motherboard Replacement
    1. Amazon Echo Studio Motherboard Replacement, Power Supply Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement, Power Supply Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement, Power Supply Board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the device upside down.
      • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
    2. Amazon Echo Studio Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
      • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
      • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
    3. Amazon Echo Studio Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Before fully removing the base, remove the three attached connectors.
    4. Amazon Echo Studio Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Now unscrew the the single 10 mm Phillips screw.
      • Remove the power supply board.
    1. Amazon Echo Studio Motherboard Replacement, Subwoofer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two screws located across from each other on the outside of the plastic ring shown.
      • Remove the plastic outer ring that hugs the inside of the edges of the device.
      • This may require you to use a soft prying tool to separate it from the outer shell.
    2. Amazon Echo Studio Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
      • Once the screws are removed, take the power supply's baseplate out of the unit.
      • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
    3. Amazon Echo Studio Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
      • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
      • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
      • Your subwoofer is now disconnected and ready to be replaced.
    1. Amazon Echo Studio Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Studio Motherboard Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the thirteen 9 mm Phillips #00 screws.
      • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
    2. Amazon Echo Studio Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
      • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
    3. Amazon Echo Studio Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
    4. Amazon Echo Studio Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the motherboard from the device by pulling it out.
      • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
Colin Nicoll
crwdns2935283:010/26/22crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-6, Petersen Fall 2022 crwdns2935289:0UMass Dartmouth, Team 2-6, Petersen Fall 2022crwdne2935289:0
UMASSD-PETERSEN-F22S2G6
where can I buy a motherboard replacement ?
Juan Daniel Hernandez R - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I also would like to know where to get a motherboard... my studio is stuck at the green ring.
Ed Wilcox - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i also would like to know. mine stuck with cyan circle
Алексей - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is there any place to buy the Amazon Echo Studio Motherboard?
DOCA - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
hi is there a place to buy this motherboard?
Bede Bede - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 80
crwdns2942667:0crwdne2942667:0 2,466
