Amazon Echo Show Motherboard Replacement
  1. Amazon Echo Show Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Show Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, use your hands to gently remove the taped-in rubber foot from device.
  2. Amazon Echo Show Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
  3. Amazon Echo Show Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Show Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Show Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Visually locate the motherboard within the device. It is the large green panel right above the speakers.
    You forgot the speaker grill and all the screws behind it to open the device. Fail!
    Bryan Hawley - crwdns2934203:0crwdne2934203:0
  4. Amazon Echo Show Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Show Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the ten 1mm T5 Torx screws holding the motherboard in place.
  5. Amazon Echo Show Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 1mm T5 Torx screws holding down a wire connected to the motherboard.
    • Remove a small piece of black electrical tape attached to the wire.
  6. Amazon Echo Show Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all the screws have been removed, you should be able to gently lift the motherboard up and out of the device.
To reassemble your device, follow these instructions in reverse order. Make sure that the ring on the black wire is attached between the circuit board and the screw, and that the black tape on the end is lined up as well.
Christina Simone
crwdns2935283:010/24/18crwdne2935283:0
576 crwdns2915208:0crwdne2915208:0
University of South Florida St. Petersburg, Team S1-G3, Stowe Fall 2018 crwdns2935289:0University of South Florida St. Petersburg, Team S1-G3, Stowe Fall 2018crwdne2935289:0
USFSP-STOWE-F18S1G3
Where can I find a new mother board
ralphm1944 - crwdns2934203:0crwdne2934203:0
Sorry, but this instruction is simply WRONG and missing some important part.
Between step 2 and step 3, you will have to peel off the speaker grille AND the glass screen of the device - behind those are also a lot of screws!! Without unscrewing them, you will NOT get your echo open.
You know that this is necessary by the way, because you mention it in your echo show teardown video.. so i do not understand why these important steps are missing here?
Simon Eriskat - crwdns2934203:0crwdne2934203:0
It is a worthless effort to show a repair process, unless there exist a source for the replaceable repair part or circuit board component.
Michael Edwards - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,963
