Follow this guide to replace the Amazon Echo Show motherboard. The motherboard of the Amazon Echo Show is responsible for managing most functions of the device. Replacement requires precision and patience, especially when working with the ribbon cables.
Orient the Amazon Echo Show 5 so that the display is face down.
Use a spudger to remove the grey bottom cover.
Remove the three screws with a T6 Torx screwdriver.
Use a spudger to release the six internal tabs lining the sides of the device.
Carefully open the device by folding it open along the top edge where the camera is located.
Remove the red and black power connector connecting to the motherboard with either a prying tool or your hands.
Disconnect the five ribbon cables connecting to the motherboard.
Remove the six 4 mm screws that are used to hold down the motherboard using a T6 Security Torx Screwdriver.
What is the mainchip/soc?
