Amazon Echo Motherboard Replacement
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
    Könnt ihr Ersatzteil machen für Amazon Echo
    Okka Mehmed - crwdns2934203:0crwdne2934203:0
    Wo kann ich Ersatzteile holen für Amazon Echo
  5. Amazon Echo Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
    I need to find a replacement board. Where can I find one?
    Matthew Webster - crwdns2934203:0crwdne2934203:0
    Me to, i need this board to my alexa echo
    benjaminaflorentino - crwdns2934203:0crwdne2934203:0
    So anyone found out where we can get these boards and other components ?
    Jimmy - crwdns2934203:0crwdne2934203:0
    I need this board to my echo 2nd, where can I find one?
    Pedro B - crwdns2934203:0crwdne2934203:0
  7. Amazon Echo Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
    These instructions are not going to help me because I am trying to repair an Alexa Echo Show.
    Tami Schaumburg - crwdns2934203:0crwdne2934203:0
  8. Amazon Echo Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard up from the Echo.
    Without a source for replacement motherboards this guide is useless.
    Minok - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Alexander Albert
crwdns2935283:002/04/16crwdne2935283:0
1 169 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-3, Wollert Spring 2016 crwdns2935289:0USF Tampa, Team 3-3, Wollert Spring 2016crwdne2935289:0
USFT-WOLLERT-S16S3G3
crwdns2947412:011crwdne2947412:0
Where can you get the mmotherboard
Glen Seay - crwdns2934203:0crwdne2934203:0
same question. where do i get replacement motherboard?
akn978s - crwdns2934203:0crwdne2934203:0
This is how to remove the motherboard not how to replace it....geez
adairt - crwdns2934203:0crwdne2934203:0
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - crwdns2934203:0crwdne2934203:0
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - crwdns2934203:0crwdne2934203:0
Any luck with finding a replacement motherboard ?
Rebel Face - crwdns2934203:0crwdne2934203:0
Where can i get the amazon echo plus motherboard ? any resellers
Shyam Sunder - crwdns2934203:0crwdne2934203:0
Where can i get the amazon echo plus 1st generation motherboard
i am in need of the motherboard where do i get it please ?
Parts can be found on eBay guys.
Andrew K - crwdns2934203:0crwdne2934203:0
No they cannot , I see zero listings for echo motherboards. If the part was produced here would be listings. Amazon produced just enough and shut production down. Manufacturer of ewaste is best I can classify amazon as given the electronic device just does after 5-7 Years of at most using electricity.
Minok -
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 15,361
