Amazon Echo Look Wi-Fi Module Replacement
  1. Amazon Echo Look Wi-Fi Module Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
  2. Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
  3. Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the front panel with an iOpener.
    • It may help to secure the iOpener to the device.
    • Heat the device for 5-10 minutes to loosen the glue.
    • CAUTION: The iOpener and the device may be hot.
  4. Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lever the Jimmy between the screen and the device until an opening is formed.
    • Insert opening picks to hold the opening as needed.
    • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
    • Step 3 may need to be repeated as Step 4 is time-sensitive.
  5. Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the front panel by levering the spudger at the top of the device.
  6. Amazon Echo Look Wi-Fi Module Replacement, Midframe: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Look Wi-Fi Module Replacement, Midframe: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws from the midframe with a Torx T5 screwdriver.
    • Lift up the midframe
    • Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
  7. Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Look Wi-Fi Module Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently lift up the ribbon until it detaches.
  8. Amazon Echo Look Wi-Fi Module Replacement, Wi-Fi Module: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the Wi-Fi module away from the motherboard.
Ryánn Gillen
crwdns2935283:009/12/23crwdne2935283:0
428 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-5, Harold Fall 2023 crwdns2935289:0University of North Texas, Team 2-5, Harold Fall 2023crwdne2935289:0
UNT-HAROLD-F23S2G5
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 372
