If necessary, removing the CPU PCB allows for a complete reset of your Amazon Echo's memory. It is easy to remove and is the first step in disassembling the rest of the device.
After removing a few screws and the ribbon cable, a new CPU PCB can be inserted. Removing it only requires a spudger for the backing and a thin prying tool for disconnecting the ribbon cable.
Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
Once removed, the Echo Dot is now able to be split in two.
Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
