Amazon Echo Dot 3rd Gen Disassembly
  1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
    • Avoid letting the Adhesive touch anything, lay the plate on the branded side
    • If the adhesive is to strong use a hair dryer to soften it
  2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a TORX T6H bit to remove the four screws on the bottom
    • When all the screws are taken out lift up and the covering should slide off
  3. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remember to un latch the ribbon cable before pulling the circuit board up
  4. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
    • Pull up on the metal to release the top from the rest
  5. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Undo the four screws the remove the white defuser piece (I lost a screw)
  6. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
Ben Nicholsonb
crwdns2935283:007/09/21crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
eduardosanchessales - crwdns2934203:0crwdne2934203:0
How can I convert Amazon Echo Dot power from AC to DC?
Gift Sikufele - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 114
crwdns2936753:030crwdne2936753:0 463
crwdns2942667:0crwdne2942667:0 14,652
