Amazon Echo 2nd Generation AMP Board Replacement
  1. Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo 2nd Generation AMP Board Replacement, AMP Board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
    Removing the rubber layer does not actually seem to be necessary.
    jrhifixit - crwdns2934203:0crwdne2934203:0
    Where do you get the replacement Pcb
    niall.mcgee1 - crwdns2934203:0crwdne2934203:0
    Rubber base removal not necessary.
    Screws for first few steps may be T10, but a quality T8 driver may also work
    Vicente Laluz - crwdns2934203:0crwdne2934203:0
  2. Amazon Echo 2nd Generation AMP Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo 2nd Generation AMP Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo 2nd Generation AMP Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
    Amp board may have two T10 screws holding tweeter speaker, do not remove.
    Hi please where can find new main board? Thanks.
    Frank Kofi Agyapong - crwdns2934203:0crwdne2934203:0
    I am from India. If you find pls let me know
    Dhanapal -
    Where can I get new main board in India
    Dhanapal - crwdns2934203:0crwdne2934203:0
  3. Amazon Echo 2nd Generation AMP Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo 2nd Generation AMP Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
Eric Inman
crwdns2935283:010/08/18crwdne2935283:0
337 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S4-G4, White Fall 2018 crwdns2935289:0Cal Poly, Team S4-G4, White Fall 2018crwdne2935289:0
CPSU-WHITE-F18S4G4
Can anyone find a replacement board?
Tristan Parks - crwdns2934203:0crwdne2934203:0
I need a ramp board for echo show second edition.if its too much ill just scrap it you know.I'm just board and tinkering with it.my friend plugged wrong amount of juice into it and fried this board I imagine because it was working fine before that
Alex Cross - crwdns2934203:0crwdne2934203:0
Is it possible to get a replacement ribbon cable for this model?
Gerry Tweedie - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,033
