Remove the 4 Torx screws of the back cover.
Pry on the side of the case to pop it open.
The back cover snaps into place, so it takes a bit of force and fidling to open.
DO NOT pull on the back cover after separating the two. There is still a ribbon cable connected.
Remove the metal cover of the ribbon connectors in order do disconnect the back case.
Disconnect the four highlighted ribbon cables.
Remove the 2 screws holding the main board in place.
Remove the PCB by gently prying on it while pushing the holding tabs back.
Gently pry between the pcb and the battery to separate the two.
