Amazfit T-Rex Pro Battery Replacement
  1. Amazfit T-Rex Pro Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazfit T-Rex Pro Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 Torx screws of the back cover.
  2. Amazfit T-Rex Pro Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry on the side of the case to pop it open.
    • The back cover snaps into place, so it takes a bit of force and fidling to open.
    • DO NOT pull on the back cover after separating the two. There is still a ribbon cable connected.
  3. Amazfit T-Rex Pro Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazfit T-Rex Pro Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the metal cover of the ribbon connectors in order do disconnect the back case.
    • Pay attention to where the screws came from. They are either black or silver, with the latter being shorter. Refer to the image when reassembling your watch.
  4. Amazfit T-Rex Pro Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazfit T-Rex Pro Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the four highlighted ribbon cables.
    • Remove the 2 screws holding the main board in place.
  5. Amazfit T-Rex Pro Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazfit T-Rex Pro Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the PCB by gently prying on it while pushing the holding tabs back.
    • Exercise caution when handling these tabs, as they are plastic and can easily break.
  6. Amazfit T-Rex Pro Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry between the pcb and the battery to separate the two.
    • Use plastic tools and avoid excessive force to prevent piercing the lithium battery. Metal tools can cause it to react and potentially leak or explode.
Tiago Rodrigues
crwdns2935283:001/24/25crwdne2935283:0
195 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 100
