Even so we know this as a clutch assembly on other washers, "Splutch" is a term used for the Whirlpool washing machines. It refers to the cam assembly kit (or splutch kit). This assembly is a main component of the transmission system. It can wear out over time and running heavy loads with a full tub of water can shorten the lifetime of a splutch. Poor wash performance as well as grinding noises while washing, are a sign of a worn splutch.
To work on this replacement, you will need to gain access to the bottom. It is best to place the washer on its front. Place a few old blankets etc. so as not to scratch the front to much. Since I did a total rebuild on this washer, I had also removed the control panel. It was easier for me to place the washer upside down :-)
First the pulley cover has to be removed. It is attached via two 5/16 bolts
Use an electric screwdriver with a short extension and a 5/16 socket to remove the right screw,
followed by the left screw, is easiest. A hand ratchet or a nut driver will of course work as well.
Remove the pulley cover
Now clearly visible are
The motor
The drive pulley
The shift actuator
The start capacitor for the motor
To remove the drive belt, lift one side up
and then pulling it to the drive pulley while continuing to pull up on it.
The belt will eventually run off the pulley
The pulley is held in place by a 13mm nut
Using a ratchet and socket to remove it.
Since the pulley will easily turn when using the ratchet, it is best to tap the ratchet handle by hand instead of trying a continues motion. It is common thread (Lefty Loosey). Of course, an impact wrench would be simpler :-)
The nut does come of fairly easy once it is loose.
Remove the drive pulley from the shaft. Next is the drive basket gear.
The drive basket gear sits on a spline on the drive shaft. Check the spline on the basket drive shaft if the teeth on the basket gear show damage.
There are four tabs that hold the splatch housing to the gearcase
more of the latches of the splutch housing.
To remove it, simply twist the splutch housing into the direction of the slotted tabs (counter clock wise) until it comes free.
One the latches are cleared, lift the locking ring and the splutch housing to remove it from the shaft.
It is important to check the splines on the drive gear. If it is severely damaged make sure that the drive shaft is in good working order.
Remove the splutch spring.
Once more, check the spline on the drum drive for any damage
Here is the Splutch Kit that was used for this replacement
Reinstall the belt.
