Aluratek ADMPF310F Replacing USB Port Replacement
  1. Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift screen out of place so you can access the plugs that connect it.
  3. Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the mother board.
    • Be careful as this zif connector is very frail plastic.
  4. Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
  5. Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out remote receiver out of its clip.
    • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
  6. Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using fingers pull the first speaker wire that is located closest to the speakers
    • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
  7. Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
  8. Aluratek ADMPF310F Replacing USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the smaller end of the motherboard.
    • Apply force pulling away from the USB ports to get the mother board out of place.
  9. Aluratek ADMPF310F Replacing USB Port Replacement, USB Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the back end of the mother board unsolder the USB port at the two points shown.
Pascal Alexis
crwdns2935283:011/05/15crwdne2935283:0
427 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-1, Martin Fall 2016 crwdns2935289:0UMass Dartmouth, Team 5-1, Martin Fall 2016crwdne2935289:0
UMASSD-MARTIN-F16S5G1
crwdns2942667:0crwdne2942667:0 275
