If your Altec Lansing Mini Lifejacket 2's speaker is damaged or faulty, use the following step-by-step guide to replace it. This guide applies to both the speakers.
Use the spudger to remove the eight black pins from the front and back of the wire screens.
Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
Remove both black and orange layers from the speaker body.
Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
Slide the mounting plate out to remove it.
mine does not have a phillips screw at the post area
Pry off the wire mesh on both sides using a metal spudger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
Pull the case apart to access the interior components.
To remove the back panel, gently pull out its wire harness.
What does doing all of this accomplish?
Is there an end result here? Now what?
What does all of accomplish? Now what? How does it fix the fact the device won’t charge at the charging port?
conclusion????? what i do now????
Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
To remove the speaker, gently pull out the its wire harness.
Remove the rubber ring from the rim of the speaker.
Where can i buy the altec lansing lifejacket 2 internal speakers online? Can you provide me the link?
Is there a part number for these two speakers? My speakers are making a crackling noise. Most likely one or two of the speakers are blown. I'm going to open it and check it. Where can I purchase these speakers online?
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
Where can I get this speaker parts?
Where can I get a complete power circuit board from for a Imw575 as mine is completely broken thank you
