Use this guide to replace the motherboard in your Altec Lansing Mini Lifejacket 2 if the bluetooth chip, microphone, or another electronic component has failed.
Use the spudger to remove the eight black pins from the front and back of the wire screens.
Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
Remove both black and orange layers from the speaker body.
Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
Slide the mounting plate out to remove it.
Pry off the wire mesh on both sides using a metal spudger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
Pull the case apart to access the interior components.
To remove the back panel, gently pull out its wire harness.
Disconnect the battery from the motherboard.
Unplug the remaining four wire harnesses attached to the circuit board
Remove the three 9.1mm Phillips #1 screws located on the circuit board.
I own the IMW778-BLU-TA model. Where can I find a replacement motherboard for it??
Nick Cote - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
same for me, anyone knows where can I find a replacement of the motherboard? thx
Travis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
need back panel replacement
rahul pande - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same here! Loved the product. Can not afford to buy something else.
Mr Shopper - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I need 2 the board for charging,usb,aux cord that plugs into motherboard.
John Proffit - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
