Altec Lansing Mini Lifejacket 2 Battery Replacement
  1. Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
crwdns2935229:08crwdne2935229:0
Stephen Albrecht
crwdns2935283:002/14/18crwdne2935283:0
1 053 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S3-G2, Nance Spring 2018 crwdns2935289:0USF Tampa, Team S3-G2, Nance Spring 2018crwdne2935289:0
USFT-NANCE-S18S3G2
crwdns2947412:011crwdne2947412:0
Where can you get the batteries? Altec Lansing doesn’t carry them.
alanp5 - crwdns2934203:0crwdne2934203:0
Search for MCR18650 battery. They are available.
F Hickisch - crwdns2934203:0crwdne2934203:0
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
rudy.ch.garcia - crwdns2934203:0crwdne2934203:0
Sounds like you need to find another source instead of aliexpress or ebay. Digikey has them with the correct 2 wire connection. It's just a standard 18650 battery with the wires spot welded to the positive and negative terminals. Anything with a 3rd wire is likely meant as a charge sensing wire for a batter that has on board circuitry.
rchuncleskeleton -
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
Edgar Corral (Tramarius) - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 85
crwdns2942667:0crwdne2942667:0 23,017
