Does your speakers bluetooth not seem to be connecting or dropping connections? The bluetooth board could be the cause.
Using your hands, remove the pegs (4+4) from the front and back of the speaker.
Remove the outer black rubber housing of the speaker.
Remove the inner blue rubber housing from the speaker.
Pull out the two black wire meshes using a metal spudger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
Pull the case apart and you will be able to see all the components inside the speaker.
Now that the case is open look for the small green (NFC) chip on the inside of the case next to the motherboard.
Disconnect the Bluetooth (NFC) chip from the motherboard.
Is this a common issue with the Lifejacket 3? I was able to use my new BT speaker twice, since it was bought last week. The speaker hasn't been dropped, in or around water, outside, left on, damaged, or tampered with.
Kat - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
