AlphaSmart Pro Lithium Coin Battery Replacement
  1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
  3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
  4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
    • Slide the battery out from underneath the clip that holds it in place.
    • The positive side of the battery is facing up.
Katy Beth Culp
crwdns2935283:010/13/14crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-1, Benson Fall 2014 crwdns2935289:0Clemson, Team 1-1, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S1G1
crwdns2942667:0crwdne2942667:0 995
