The Alldaymall A88X has a built in speaker is mounted on the inside of the back panel and is soldered to the motherboard. This guide will walk you through the process of removing the existing speaker and installing a new one.
Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
After the speaker has been removed, place the rear panel aside.
Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
Using a pair of tweezers, begin separating the tape downwards from the back panel.
Pull the tape away from the wire bundle beneath.
Isolate the wire running from the speaker to the motherboard.
Desolder the speaker wires from the motherboard.
