Alldaymall A88X Camera Replacement
  1. Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement, Alldaymall A88X Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
    • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
    • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
  2. Alldaymall A88X Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
    • When removing the speaker, make sure not to disconnect the wires in any way.
    • After the speaker has been removed, place the rear panel aside.
  3. Alldaymall A88X Camera Replacement, Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement, Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement, Speaker: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully separate the speaker wire from the tape and proceed to peel the tape off in an upwards direction.
    • The tape we are removing covers a number of connections on the motherboard. Be extra careful not to sever any of these.
  4. Alldaymall A88X Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a pair of tweezers, begin separating the tape downwards from the back panel.
    • Pull the tape away from the wire bundle beneath.
    • Isolate the wire running from the speaker to the motherboard.
  5. Alldaymall A88X Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the speaker wires from the motherboard.
  6. Alldaymall A88X Camera Replacement, Camera: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement, Camera: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement, Camera: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a nylon spudger, slowly work your way underneath the battery separating it from the panel beneath.
    • After the battery is separated from the panel make sure to place it face down above the tablet itself.
    • Throughout the removal process keep an eye on the battery's wires and make sure they do not break.
  7. Alldaymall A88X Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the wires that connect the battery to the motherboard.
  8. Alldaymall A88X Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pair of tweezers begin to peel the tape covering the ribbon cable on the motherboard.
  9. Alldaymall A88X Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a pair of tweezers begin to peel the antenna from the metal panel.
    • Work your way down until the antenna is completely removed.
    • Be careful not deform the antenna or sever its connection.
  10. Alldaymall A88X Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of tweezers remove the tape securing the cameras to the back panel.
  11. Alldaymall A88X Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool lift up the flap on the ribbon cable receptacle.
  12. Alldaymall A88X Camera Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alldaymall A88X Camera Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pair of tweezers remove the camera assembly from its housing and its receptacles.
Drhaber
crwdns2935283:002/10/16crwdne2935283:0
985 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-1, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 4-1, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S4G1
crwdns2942667:0crwdne2942667:0 367
